I am using the student version as a Revit plug in for a building.
In one area of the model, I have an open arcade, that I want to understand how the wind moves in the building as well as around it.
However whenever I run the Flow analysis, the arcade region always shows dark blue, as if there is no air at all.
Does Flow Design read openings as solid? How should I go about analyzing this region?
I would thing there would be some type of velocity within the arcade right?
Thanks!
Solved by S_May. Go to Solution.
