Flow Design Forum (Read Only)
Welcome to Autodesk’s Flow Design Forums. Share your knowledge, ask questions, and explore popular Flow Design topics.
Flow Design plug in is not recognizing openings in the building model
1 REPLY 1
mlm474
478 Views, 1 Reply
I am using the student version as a Revit plug in for a building.
In one area of the model, I have an open arcade, that I want to understand how the wind moves in the building as well as around it.
However whenever I run the Flow analysis,  the arcade region always shows dark blue, as if there is no air at all.
Does Flow Design read openings as solid? How should I go about analyzing this region?
I would thing there would be some type of velocity within the arcade right?
Thanks!
1 REPLY 1
S_May
in reply to: mlm474
Hi @mlm474
FlowDesign wird nicht mehr unterstützt, bitte mit CFD arbeiten
"FlowDesign is no longer supported, please work with CFD"
