Is there a way in Flow Design to find the Center-of-Pressure location where all the aerodynamic forces balance?
Solved by Xiaojin.Zhang. Go to Solution.
Unfortunately, it is impossible to do it by Flow design.
I would suggest you add this feature to the idea station.
By the way, Autodesk Simulation CFD can determine this result for you.
Thank you!
Xiaojin
Thanks for your reply. I had a feeling that it couldn't.
Do you know what the reference area the software uses to calculate the drag coefficient?
