Update June 27, 2017: Upgrade versions FloWorks 17.1.2 and FloWorks 17.0.5 are now available.
These releases resolve an incompatibility that may result in errors on starting FlexSim when you install FloWorks in combination with certain other modules. If you want to use the (beta version of) the Emulation module, for example, you should upgrade FloWorks to this latest version. There are no functional changes.
If you are using the LTS version (17.0.5) of FlexSim you should upgrade to FloWorks 17.0.5.
Download FloWorks 17.1.2 if you are using FlexSim 2017 Update 1 (FlexSim 17.1.2).
Both versions can be found in the Downloads section of your FlexSim account on the 3rd party modules tab. Bugs may be reported to support@talumis.com.
FloWorks is a 3rd party module developed and maintained by Talumis BV ( talumis.com). It provides faster and more accurate modelling and calculation of fluid systems than the default FlexSim fluid library. It is especially useful within the oil, gas, and bulk industry both for production and supply chain optimization. This module requires a FloWorks license.
For any questions, please email support@talumis.com.
The following bug fixes and usability improvements are available in both versions:
The following bug fixes apply to version 17.1.1 (FlexSim 2017 Update 1) only.
The release notes of older versions of FloWorks can be found here.
FloWorks 17.1.1 looks like to have some trouble with the beta Emulation module.
Please check it in ;
https://answers.flexsim.com/articles/39409/emulation-module-beta-now-available.html
I explained it in detail.
@david.seo we have just released a fix that allows FloWorks and the Emulation module to be present simultaneously.
