FlexSim 2018 Beta is available. (updated 8 Dec 2017)
To get the beta, log in to your account at www.flexsim.com, then go to the Downloads section, and click on More Versions. It will be at the top of the list.
If you have bug reports or other feedback on the software, please email dev@flexsim.com or create a new idea in the Development space.
I expect 2018 version will make customers and us happy.
I hope the Date Time Source activity will be included in the 3D Source object as a pick option list of Arrival Style.
I think the feature of it to be needed right now.
You can add a Create Objects activity after the Date Time Source to generate flowitems in the model.
We have no plans to add this functionality to the 3D Source object.
hi,
It seems the Excel import is completely broken - is this a problem others are having as well? I can't get it to import either Excel 2016 or Excel 2013 files and it also says the table I have selected doesn't exist every time.
exception: Exception Caught in ExcelAuto::importData(int startrow, int startcol, int rows, int cols, int curtable, double percentdone, double percentmain) object: /Tools/ExcelAuto exception: Exception Caught in ExcelAuto::importTables(int onreset) object: /Tools/ExcelAuto exception: Exception Caught in ExcelAuto::doImport() object: /Tools/ExcelAuto exception: Exception Caught in ObjectFunction101__project_exec_commandlist_excelmultitableimport_node object: MAIN:/project/exec/commandlist/excelmultitableimport/node i: MAIN:/project/exec/commandlist/excelmultitableimport/node class: MAIN:/project/exec/commandlist/excelmultitableimport/node exception: Exception caught in TreeNode::callMemberFunction() c++/dll execution. Throwing... MAIN:/project/exec/commandlist/excelmultitableimport/node c: MAIN:/project/exec/commandlist/excelmultitableimport/node i: MAIN:/project/exec/commandlist/excelmultitableimport/node thisClass: MAIN:/project/exec/commandlist/excelmultitableimport/node exception: Exception caught in evaluation of MAIN:/project/exec/commandlist/excelmultitableimport/node
I'll get this on the dev list. Thanks for the feedback!
Can you send in a model and excel file that demonstrate the problem? I tried a few excel files, but couldn't replicate the issue.
Hi Jordan,
Here's an empty model and excel file which cause the same error for me.
The download page still shows the same version number and the old release date:
But the file itself appears to be updated and signed on 01 December 2017. The product version of this update is 18.0.0.433. The previous update that I have downloaded was signed on 10 November 2017, and the product version was 18.0.0.409. Both files have the same name.
Could you please announce SHA256 and put the full product version or release date in the file name of the installers, just for the sake of being able to distinguish different installers/updates?
As in the previous versions, the Time plot is not showing the line (or the dots) if the values don't change during the time. You can see this on the attached model where the value is always 14
Additionally, in my opinion it would be very useful to introduce the possibility to set the Y axis range limits when we don't want to be the graph itself to change them basing on the minimum and the maximum values.
The new person replacing with the old TaskExecuterFlowItem does not move as expected in Process Flow module.
When making the tutorial model of Flexsim Basics Tutorials 1.4 - Link the Models, the person does not move after creating Object: Customer like followed model.
Please check it again.
This model has an old Person in it; not the new Person.
Where did this model come from? Did you open an older model and then start building the model?
If you start a new model in 18.0, then the FlowItem Bin has a new Person in it. If you open an old model, the FlowItem Bin has whatever was in it before.
I made the model using the previous beta version of November 10.
I changed the create Object Activity to new one. Is it not valid? If I want to use the previous version model, what should I do? Should I abandon the model and make the new one newly?
There is no "new one" Person in this model. The "Person" in this model's flowitem bin is the old, static person that does not animate. In this model's flowitem bin, you don't have any taskexecuter flowitems.
If you add one and then select it in your Create Object activity, then it will work:
On a side note, we will update the Flexsim Basics Tutorial to reference the Person now instead of the TaskExecuterFlowItem, because the TaskExecuterFlowItem is no longer in the list for new models.
seems to have been fixed in the beta update, thanks!
