Vertical acceleration for ASRS
I would like to suggest adding a vertical acceleration parameter for ASRS movement, since I'm facing this limitation in the models I'm currently developing.
I've seen a few posts complaining about it, but I think it hasn't been posted as an idea yet.
Thanks in advance!
1 Comment
Theoretically you can reduce a constant velocity a bit to get sufficiently accurate travel times. An acceleration would slightly improve  a real motion profile. And in a case where you have to analyse a motion profile, because you might collide with obstacles then this tool wouldn't deliver sufficiently results.
