I believe there is an issue with applying the "No_Connection" option to a Network Node Path via the right-click context menu.
As shown in the attached image, I have a path connecting two network nodes. When you right-click the direction arrow on this path, a menu appears with options to set the path as Passing, NonPassing, or No_Connection.
If I left-click to select "No_Connection," the selected arrow correctly turns red, visually indicating that movement in that direction is restricted. However, when I run the actual simulation, I can see that the AMR ignores this setting and continues to travel along the restricted path.
I have attached the model file demonstrating this behavior.
