In the Processor properties, when you use the sampler to pick an operator, it returns 2 suggestions:
- using a pointer (often the most preferred way)
- or using a Model.find() syntax
In the MultiProcessor properties, when you use the sampler to pick an operator, it returns only 1 suggestion:
- using a Model.find() syntax
It would be more convenient if the sampler also suggests to get a reference to the operator using a pointer.
