Message Trigger Bug in Photo Eye of Conveyor Module
I report a bug in Message Trigger of Photo Eye in Conveyor Module.
GIF
You can see the gif attached, When I erase the default option in Message Trigger, the code will become:
treenode current = param(10);
which it should be
treenode current = param(9);
treenode conveyor = param(10);
3 Comments
jing_chen
jing_chen
I found another bug about PhotoEye in Conveyor Module.
I built a conveyor system which including some PEs under model, then I copy the whole conveyor system to a plane. After that I found the PE seems strange with different Z-axis.
You can see the model attached.
pe-show-bugv2016.fsm
philboboADSK
Thanks for pointing these bugs out. I've added them to the development list.
