Greetings Everyone,
I recently set up a web server to provide stakeholders in my organization with access to our FlexSim work. While rendering some of my older models on the web interface, I noticed that the text size appeared significantly larger than what I had originally designed in the FlexSim application.
After investigating the issue and experimenting with available font size settings, I discovered that creating a new model with base units set to meters (instead of feet, which most of my existing models use) resolved the problem. However, when I tried updating the font properties in my older models from feet to meters, the text still did not render correctly on the web interface.
The only workaround I found was resizing the fonts directly in the application, but this negatively impacts usability in the original models because it makes important data harder to read.
If this behavior is not a bug and there’s a recommended approach for preparing older models for web rendering, I would greatly appreciate any guidance.
Thank you!
