bugs & questions in 2019
I found 2 bugs in 2019 beta (30th of november build). tested in a demo version:
1. If you drag in a multilocation, check the Edit mode, change the location to a higher number ( I used 18) uncheck the Edit mode check box and press reset, the amount of locations is a back to standard (being 9)
2. Right click in 3D you will get the popup menu and there is a typo in transport group:
3. If you enter a name in the Name column of the data time source (of the arrivals process flow that is automatically created in a people flow model), that name is given to the token that is created but how can you put that name on the 3D object that is created?
2 Comments
philboboADSK
We fixed #1 and #2. Thanks for bringing those to our attention.
For #3, this is how all of the ProcessFlow Source activities work. If you want to rename the person in the 3D view, use a Custom Code activity with the Set Name picklist after the Create Person activity:
The Arrivals ProcessFlow is there to quickly create common starting activities that you would want when creating person flows. You are welcome to customize it to your needs afterwards.
SCHamoen
@phil.bobo Hi Phil, thanks for the answers. Concerning point 3 I should have been a bit more clear maybe. What I found a bit counter intuitive is that in the Date Time Source you have a number of columns and if you add labels there you will get extra columns. All the label information in those columns is passed on to your 3D object if you keep the check box in the Create Person checked, except the Name. So all columns have an impact in 3D except the Name. Which is fine and a choice, I just wanted to point out that it felt a bit strange.
