Add AStar Navigator Barriers into Model Layouts
The idea is use the AStar barriers as a comon object in order to use diferents scenarios with the model layouts, for example: to create diferents routes for TE´s.
I tryed to use the divider and the one-way divder into the model layouts with two diferent positions, but is not possible set and change the layout options. I think that will be very interesting use this visual tool with the model layouts, and the experimenter for test new routes for TE´s.
Thank you
1 Comment
chris_smith7
Hi @Rodrigo Lamas,
You might be interested in this post:
How can astar barriers be created in FlexScript?
By creating the barrier on model reset with different values it is possible to do this. It does currently take some scripting, but it is possible.
