Access model parameters with dot syntax
When you create labels on objects, you can easily access your custom labels with dot syntax:
When you create parameters in a Model Parameter Table, the dot syntax suggests nothing:
It would be nice if model parameters could be found easily when using dot syntax.
If you agree with this idea, please vote for it.
2 Comments
This is a great idea. Thanks for pointing it out. I'll make sure it's on the dev list.
@Nicolas Mbz This has been partially implemented in the 23.0.11 and 23.2.1 bug fix releases today. That window can now be resized horizontally. We will add vertical resizing in a future release.
