Access model parameters with dot syntax
When you create labels on objects, you can easily access your custom labels with dot syntax:
When you create parameters in a Model Parameter Table, the dot syntax suggests nothing:
It would be nice if model parameters could be found easily when using dot syntax.
If you agree with this idea, please vote for it.
2 Comments
mischa_spelt
Seconded!
And even cooler would be if code completion would also work on the array notation (so when you type Model.parameters[ it will auto-suggest parameter names like it does for Table(. And then of course for object.labels[ too 🙂
ClairAu
Thank you @Mischa Spelt for your feedback !
