[20.2 Beta] Don't move properties popup when a section is collapsed
[ FlexSim 20.2.0 ]
How to reproduce:
- install 20.2 Beta build 708
- create any FR object
- double click the object
- expand one of the sections (e.g. Labels)
- collapse the section
What is observed: the popup moves to the left. What is expected: it doesn't move.
8 Comments
matt_long
We've been trying to duplicate this issue. Can you give us any more information?
What windows are you running?
What are your DPI settings set to?
Screen resolution?
A short video of this occurring could help.
sastanin
I uploaded a video https://weboffice.flexcon.it/weboffice/index.php/s/hH5CNjLxJBTvH7j
Running Win10 Pro x64. nVidia Quadro P3200, driver version 26.21.14.3206 (432.06) + Intel UHD 630, driver version 26.20.100.7755. nVidia Control Panel settings are mostly left as defaults (Preferred graphics processor: auto-select). The native screen resolution is 1920x1080, the same as the external monitor. I use 125% scale factor ("Recommended") when the external monitor is not connected, and 100% otherwise. The effect can be observed in both scaling modes.
philboboADSK
Even with the video, we're still struggling to replicate the issue.
We also noticed that in the video, it is setting the name edit field caret to the beginning of the field. That's not supposed to be what happens by default. It should be highlighting the name so that you can easily rename an object by double-clicking without having to drag a selection in the edit field.
Do you have custom changes in the view tree or custom modules loaded?
philboboADSK
Can anyone else replicate this issue? Perhaps if we had more than just Serge's information, we might be able to discern what is causing the issue.
philboboADSK
@sergey.a
We've been unable to duplicate this error, but now we've gotten a second report of this happening.
My best guess is that it is related to your monitor workspace configuration settings.
Can you tell us more about your Windows "Display settings"? Right-click the Windows desktop and select "Display settings" to open the window. Please post a screenshot showing the monitors and their positions. Also let us know which monitor is the main monitor and what the "Scale and layout" size percentages are for each monitor.
For example, here is a screenshot showing this information on my computer:
Monitor 2 is the main monitor, and both monitors are at 100% size scaling.
philboboADSK
@sergey.a
We're still trying to debug this. Any more information you can give us about your computer and display settings would be helpful.
sastanin
Hi @phil.bobo
Sorry I was AFK for two weeks. [edit] You can find my display settings below, but I believe that the issue is related not to the scaling settings but to the position of the Windows taskbar. I prefer to keep it on the left side of the screen to save vertical screen space.
When the taskbar is on the left, the location of the properties panel is not calculated correctly. See the video:
https://weboffice.flexcon.it/weboffice/index.php/s/LFnBfesMk69XxIg
Possible workaround: put taskbar to the bottom or to the right.[/edit]
And these are my display settings:
(That's the laptop screen without any external monitor attached; the issue can be reproduced).
Advanced settings:
Image.pngThis is a dual video-card system, and nVidia Quadro P3200 is supposed to kick in when necessary
philboboADSK
Excellent. Thank you. The task bar on the left side is causing the issue.
Now that we can replicate it, we'll see what we can do about fixing it.
Thanks again.
