Why the import doesn't work correctly ?
nicolas_membrezSQWTQ
Observer Observer
Observer
Observer
Hi, I'm would like to import a csv table in a global table by code.  The current result is a global table with one colomn. The result should be a GT with several column.
How can I correct it ?
By the way, how can we make privates questions ?
kavika_faleumu
Hey @nicolas_membrezSQWTQ, I tried running the script you made, and it seems to work for me. I got a table with the correct number of rows and columns.
Have you tried running it again recently?
moehlmann_fe
Could be an issue with the OS language setting. If commas are used as decimal delimiters in the set language then the expected delimiter between values in the csv would become semi-colons. Though if the file opens correctly in Excel it should also be imported correctly into FlexSim.
kavika_faleumu
That is a possibility. I can investigate further with that hypothesis. Thank you for your insite!
kavika_faleumu
I was able to confirm that this is due to regional settings. For example, when in set my OS's country and regional formatting to Spain, the import doesn't work properly.
I'll add this to the dev list as a bug.
kavika_faleumu
According to the docs of the importtable command, you can set the listseparator and decimalseparator parameters, which lets you determine what your separators are, regardless of region. Have you tried setting those?
