Why "Release Equipment" for a CrashCart resource is not working in this case?
sara_s2
sara_s2
[ FlexSim 19.0.0 ]
In the process flow "ReplenishProcessFlow" - of the attached model - the nurse ‘Female1’ replenishes the cart with medicines (boxes) then moves the cart to the patient’s bed for administration. After administration, she must return to the rack for the next replenishment. "Move cart then administer" process is working, but "Move cart for next replenish" is not working. The problem is like if the 'Cart' resource was not released in "Move cart then administer" process !
I really can't understand this problem. I would be grateful for your help.
Regards.
hospital1.fsm
Matthew_Gillespie
On the Acquire Equipment and Acquire Staff activities the Puller field is still set to token.Person, but the token doesn't have a Person label. Since this part of the process flow doesn't seem to be associated with a patient I changed the puller to just say token in these activities.
fixed.fsm
Matthew Gillespie
FlexSim Software Developer
sara_s2
@Matthew Gillespie Thank you so much for your help.
