Why is the simulation model crashing?
MoisesRocha
MoisesRocha
[ FlexSim 23.2.0 ]
Questão10c.fsm
Could someone explain to me why the simulation model is crashing during the simulation? the flowitems at a given moment do not move and therefore the simulation stops
gustavo_teodoroD8NVF
Apparently it's a bug. I tested with different random seeds and, at some point, the model crashes. To resolve the situation, I separated the conveyors and added 4 entry transfers, which connect the conveyor of each product type to the main one. Therefore, the model no longer crashes.
Solution.fsm
Jeanette_Fullmer
Hello @moises10rocha,
The merge controller is supposed to be used with in line transfers instead of side transfers. You can see more details about that in the following post.
If you change your max angle for in line transfer then the model will work.
I have asked that this be updated in the conveyor tutorial.
MoisesRocha
thanks
MoisesRocha
thanks
