Why is my process flow not rendering?
demarcus_h
demarcus_h
[ FlexSim 17.1.4 ]
My model loads fine, however, my process flow isn't loading. Anybody have an idea what might be the problem?
exception: Exception caught in TreeNode::callMemberFunction() c++/dll execution. Throwing... VIEW:/active/MainPanel/BackPanel/SplitterXPane/SplitterYPane~2/SplitterXPane/TabPane~2/TabControl/ProcessFlow>eventfunctions/onDrawCallback c: VIEW:/active/MainPanel/BackPanel/SplitterXPane/SplitterYPane~2/SplitterXPane/TabPane~2/TabControl/ProcessFlow thisClass: VIEW:/active/MainPanel/BackPanel/SplitterXPane/SplitterYPane~2/SplitterXPane/TabPane~2/TabControl/ProcessFlow
JordanLJohnson
This can happen if the model is corrupted, so that the model will open, but the tree can't be shown. Can you view the process flow in the tree? If not, then there isn't a lot you can do. If you can explore the process flow tree (MODEL:/Tools/ProcessFlow/YourFlow), then you may be able to see something suspicious.
As another possibility, does opening the default workspace and then opening the process flow new resolve the issue?
Jordan Johnson
Principal Software Engineer
Ben_WilsonADSK
@DeMarcus H, here is some general information regarding model corruption and potential mitigations:
https://answers.flexsim.com/questions/27522/my-model-wont-openmy-model-is-emptymy-model-crashe.html
