I am trying to create a model that doesn't use port connections. In the attached model, the destination of a flow item created by Source2 is set manually in custom code for the OnCreation Trigger. The flow items seem to be created correctly: when I click a flow item created by Source2, I see the label "destination" set correctly. However, the AGV never picks up flow items created by Source2. Why not?
TIA.
