Why does the 'Display Object Stat' in Text Visual Tool only display integer values instead of real values?
stan_e_davis
stan_e_davis
[ FlexSim 16.2.0 ]
When using the Text Visual Tool to display the Average Staytime, the value is being displayed as an integer instead of x.xx. I verified this occurs when performing Lesson 2 Extra Mile on page 149 in the FlexSim_16.2.0_manual
joerg_vogel_HsH
If you link into the source code, the command numtostring(num value) hasn't got any optional parameters. If you add those parameters numtostring(num value,0,2) you can see decimal values,too.
Manual numtostring
stan_e_davis
Thank you!
