[ FlexSim 18.2.2 ]
I'm trying to process some tokens by case with a switch command that requires an integer.
I have some custom code that looks up a WType string in a table and assigns an WTypeVal label to the tokens. I want to use WTypeVal in the switch command. However, I seem to only get 0 assigned to the integer variable Wtype. I've tried a dozen variations with the same result. I've posted a pic of the model. It is difficult to post the whole model as there is client proprietary info in it.
As you can see the custom code is in a subprocess. The token in question has WTypeVal of 3. I only get Wtype of 0. I assigned 15 to Wtype just to prove it changes to 0.
It seems that Parent, Child relationship is a bit fuzzy going to a subprocess with custom code because many of the Label names do not show up in the pick list when entering code.
Any help is appreciated.
Scott
