Why does ControlPoint by code not show properly?
martin_k5
martin_k5
[ FlexSim 21.1.4 ]
I have a question. When I create ControlPoint by code, it does not show properly only after I move that controlPoint by mouse it is shown properly. It is not about the visual side, but it does not work for the AGV network until I move it by mouse. These are pictures of how it creates by code and how it looks after I change its location manually.
Does anyone knows how to deal with it?
Thank you.
Martin
philboboADSK
function_s(controlPoint, "finalizeSpatialChanges");
Phil BoBo
Sr. Manager, Software Development
martin_k5
thanks for your answer, I tried to use this line of code. In the easier model (where I only create a control point and locate it on the generated path) is does work, the little cross appears, but when I do this in a bigger model such as warehouse model it does nothing and I do not know, where is the problem... Can you give me an advice?
Thank you
martin_k5
Little update, I had to make a new script and there I could use this function to make the proper positioning of the control point.
Thank you for your help.
