Why do patients not cross dividers but the worker will cross dividers?
kelly_s
kelly_s
[ FlexSim 19.2.4 ]
Matthew_Gillespie
Patients are automatically connected to the A* navigator if you have any A* objects in the model. You need to connect staff members to A* too if you want them to respect A* objects. You can do this by double clicking the A* Navigator object in the model and then in the Members box hitting the green plus button, then choose Staff and hit Select. All your staff members should now have a purple circle under them indicating that they are connected to the A* navigator. You can also add locations to the navigator if you want people to not walk through them.
Matthew Gillespie
FlexSim Software Developer
kelly_s
Thanks Matthew, I would like to add locations and Props also.
Matthew_Gillespie
You add Locations and Props in the same way. You can even select them all at the same time after pressing the green plus button:
Matthew Gillespie
kelly_s
Thanks for all of your help
