Why can't the combiner work when I use code
AriaZhou
AriaZhou
[ FlexSim 25.0.0 ]
I use code created Q1 and Q2, and connect this two queue to combiner1. But when I create some boxes on Q1 and Q2, the boxes won't flow to the combiner, I checked the input port of combiner, it is correct.
Below I am attaching the ss and model, kindly can anyone guide me in fixing the issue. Thanks in advance !
CombinerDoesn'tWork.fsm
PabloCASP
"I thought it was enough to open the input ports of the combiner (openip(Model.find("Combiner1"), 1);), but I realized that the component table structure in the tree is missing in the combiner if you have not reset the model(open the tree of a combiner after making the connections, and only then when pressing reset the node From Input Port x and its subnodes Target and Current Quantity are created)."
AriaZhou
Thanks Pablo! The target function for my model is that I want to make sure each time when I press reset, the input queue can destroy and recreate (by different commands), and then re-connect, but I think I'm now in a deadlock, maybe execute the contextdragconnection command in the processflow is not a good method. Thanks!
