Which is better [Close output] or [Stop output]
__ANON_USER__1
__ANON_USER__1
[ FlexSim 19.0.9 ]
I want to supply 10 items from Source1.
using trigger
in condition,
I have set "current.stats.output.value == 10".
in action,
Which is better, [Close output] or [Stop output]?
How are the two different?
sebastian_hemmannE3JAU
Hi anonymous user, the big different I see between this 2 options is, that no matter how often "Close output" was called it needs one "Open Output" to resume the output. If you "Stop output" you will need as many "resume output" as times you´ve called the stop outputs!
2x close 1x open -> open
2x stop 1x resume -> still stopped
2x stop 2x resume -> resumed
So for your problem this should not really matter.
__ANON_USER__1
This is exactly what I wanted to know.
Thank you!
