which command return if label doesnt exist in item?
gabriel_illescas_cavazos
mischa_spelt
If you want to know whether the label exists and has a "truthy" value, you can use the question mark:
if(current.maynotexist?) {
 // current.maynotexist exists and is non-zero, or points at a valid object
If you just want to know if it exists, you can do
treenode maynotexist = current.labels["maynotexist"];
if( maynotexist ) {
  // the node exists, get its value with maynotexist.value
However, you don't need the latter construction very often, for example, if you want to create the label if it does not exist, you can
current.labels.assert( "maynotexist" )
and if you assign a label with
current.maynotexist = 1;
it will be automatically created.
I want to set this condition for example if any label exist do nothing but if the label doesnt exist do something how can I do it?
Jacob_Gillespie
@Gabriel illescas Cavazos
if(!obj.MyLabel? && obj.MyLabel? != 0) {
    // Label not set
    // Do Something
what does it mean "!" when you star the if?
A "!" is a logical not.
This will return true only for strings that start with h:
text.startsWith("h")
This will return true for any string that starts with any letter other than h:
!text.startsWith("h")
Matthew Gillespie
FlexSim Software Developer
vedant_g1
I tried the ? method but it doesn't work for me
