Where is the DateTimeSource field NAME placed or used?
patrickABAWF
patrickABAWF
[ FlexSim 18.1.2 ]
In the process flow DateTimeSource there is a column called NAME which I use to place a distinct identifier of the persons I'm modeling. But this NAME field is nowhere to be found either on the persons or on the tokens. As far I can find it's not used or at least not accessible. Am I correct?
I compensated by adding a Label column with that same info which creates a label on the person but that seems redundant since there already is a column called NAME.
tanner_p
Hi Patrick,
As far as I know, you are correct that the Name field that you are referring to is not visible as a label. I believe that it is used simply for the user to differentiate between the outputs. If you increase the labels to "1", however, you can create a label which is accessible like normal on your tokens. I've tried to illustrate this in the image below. Hope this helps!
regan_blackett
A token names should show up like this on the token properties, and it's accessible with expressions like token.name
patrickABAWF
Regan, I saw that my Name column was number data since the table is imported from Excel and the importer automatically set this column to number. For it to work I have to make sure to change the column to String after the import is done.
Secondly, the name does show as in your picture when I click on the token but only on the token in the general process flow that creates the persons. The name does appear when I click on the token in the instanced taskexecuter process flow that controls the persons or if I click on the person itself in the 3D view. I made sure "Copy token labels" is checked but that only copies the labels and not the name.
I compensated that by creating a name label on the token with a value of token.name and doing that before I 'CreatePerson' so that this label will be also on the person.
It works but it seems like a bug. As well as the thing above with the column data type.
Matthew_Gillespie
This is not a bug. A token's name is not a label so the copy token labels checkbox doesn't copy it. A name is not a label.
Matthew Gillespie
FlexSim Software Developer
