When using global table, how to looked from column 1 and whole row
az87416
az87416
[ FlexSim 22.0.1 ]
This question is about lookup the global table column 1 and whole row.
In this model, I want to ask the AGV cart to the specific rack(and each rack represent a type ), so I use the Global Table to choose the specific type.
I want lookup from Global Table(named "AssignedToRack"),but I don't know how to looked from column 1 and whole row. like: lookup row1->row2->row3...
I had read more tutorial to try, but still not find the appropriate answers.
is there any smart way to do this operation?
Kevin
moehlmann_fe
Observer
Observer
I don't quite understand your goal. What value should be assigned to the token label?
- All values from the column as an array [1, 2, 3, 4, 5, 6, 7, 8, 9, 10]
- A single value from a random row
- First token gets the first row, second the second and so on...
az87416
Thanks for answer me.
My goal is - First token gets the first row, second the second and so on...
moehlmann_fe
Observer
Observer
To assign the row values to tokens in ascending order you can use the input statistic of the activity.
"getstat(activity, "Input", STAT_CURRENT)" returns the number of tokens that have entered the activity. If you combine it with the modulo operator "%" you can repeatedly return the values from 1 to 10.
(1, 2, 3, ...10, 1, 2, 3, ...)
(getstat(activity, "Input", STAT_CURRENT)%10)+1
kivasystem-2.fsm
az87416
it's very clear! I get it.
Thanks for help
az87416
Thank you for your previous answer, it's a great help!
In this model, I hava other question need some help
Here is the question: https://answers.flexsim.com/questions/115619/how-to-generate-the-lable-value-from-1-to-100-must.html
