[ FlexSim 16.2.2 ]
Hello, i'm searching for a simple solution via scipt to replenish a queue when an itemtype exits. It needs to replenish with the same itemtype that left the Queue.
Queue 1 has a "do not release" send to port as i don't want it to release until an item type leaves queue 2. But there are 5 different item types, so i don't want the pull to just pull the next in line item type from queue 1.
I've tried with the exit triggers to activate the pull requirement. But i can't figure out how the pull requirement can determine what itemtype just left Queue2 and call that one. Perhaps the sendmessage to Queue 1 from Queue 2 would be a good strategy, but i don't know how that would look via code.
QUEUE 1 ---> QUEUE 2 (leaving queue)
My entire model is built from GUI script on opening, so code solution is most desired.
Thanks in advance!!
