What the differences between receiveitem() and openip()
yue_y
1 View
yue_y
[ FlexSim 19.1.1 ]
Both functions can open the port and accept one flow item. How are they different from each other?
Jacob_Gillespie
The answer to this question is the same as this other one you asked:
Behavior of receiveitem() vs open port
openip(object, 1);
This allows you to open a specific port on an object.
object.input.open();
This will open all ports on the object.
Also the receiveitem() documentation says:
This function should only be used from within a BasicFR's or BasicConveyor's code fields, as other objects implement receiveitem() on their own.
