The Event object is the object that fired the event that is causing the statistics collector to update the table.
Event Object Label Value writes code like this:
current.SomeLabel
Name of Event Object Label Value writes code like this:
current.SomeLabel.name
Note that the second assumes that SomeLabel is a pointer to another node.
Could you please give sample model using above codes.
@jordan.johnson could you please give some sample model which expalins the above two plz.
Here you go. The Statistics Collector listens to both Queues, and records the value of an Event Object's label, as well as the name of the value of an event object's label.
