What is the error in this code?
paul_alejandro_r
paul_alejandro_r
[ FlexSim 18.1.2 ]
I am trying to insert the input from a sink in a database, however, it is displaying this error.
I have checked the code and I can`t find the mistake.I have used this code before and it has worked pretty well, but now I don`t know what happened.
The names from the data base match the code, so that is not the problem.
Please help me to find the mistake. Thanks. (I can`t post the code because flexsim does not let me)
JordanLJohnson
It looks like you are using the accent/grave character: `
Try with the apostrophe character: '
Jordan Johnson
Principal Software Engineer
paul_alejandro_r
Thak you @jordan.johnson.In effect, the character you mentions was the problem. I was able to fix it.
