WebServer problem
WebServer problem
fiona_k
WebServer problem
fiona_k
[ FlexSim 20.2.0 ]
When I try to execute the WebServer, an error occures. I already changed the port, but unfortunately that wasn't the answer. Hopefully somebody can help. 33049-1601453302101.png
Ben_WilsonADSK
Hi @fiona.k,
The error message does seem to point to an error listening on the given port. I can reproduce your error by trying to start the webserver using a port number that is already in use.
You may want to try on multiple different ports, in case your alternate port was also busy. You'll need to find an available, unused port number.
Ben_WilsonADSK
Hi @Fiona K, did you test with multiple other port numbers? Was there any change?
fiona_k
Hi @Ben Wilson,
thanks for your help. Actually I didn't had to change the port again, because after another restart of the computer, the webserver works.
