WebServer on Windows Server 2022?
lars_jacobsen_ScandiSim
[ FlexSim 23.0.5 ]
When running WebServer on a dedicated PC, what is the best option for operating system? Normal Windows or Windows Server?
JordanLJohnson
There isn't too much difference between Windows 11 and Windows Server 2022. Either should work fine for hosting the WebServer on a dedicated PC. The choice is mostly preference rather than functionality. For extreme hardware situations, such as installing 2 TB of RAM (~2048 GB), Windows Server would work better. But that is unlikely to apply to your case.
Windows Server has a couple variants: Windows Server Core and Windows Server Nano. If you run with Core, you won't be able to stream from the Webserver because you won't be able to get a Graphics Context. If you run with Nano, FlexSim won't launch at all; its dependencies cannot be installed on Nano.
Jordan Johnson
Principal Software Engineer
Jeanette_Fullmer
Hi @Lars Christian J2, was Jordan Johnson's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
