Webserver not showing dashboard values
visakh_sakulan
Message 1 of 8
visakh_sakulan
[ FlexSim 17.2.2 ]
When I run the flexsim model in web server the dashboards are not showing anything.
Replies (7)
Message 2 of 8
Jacob_Gillespie
@Visakh Sakulan Can you share the model that was giving you problems?
Message 3 of 8
visakh_sakulan
@Jacob Gillespie I don't have that model, I have attached another sample model which is also having the same problem.
model.fsm
Message 4 of 8
Jacob_Gillespie
The model you attached is using one of the new generic charts. Unfortunately we haven't updated the FlexSim WebServer to support these yet.
In the original two screenshots you sent, the charts look like legacy charts which should be supported. I have run into problems with some of the Process Flow charts before.
Message 5 of 8
m_rosadini
Hi Jacob, is this still the case? We have a customer asking this @Jacob Gillespie
Message 6 of 8
Jacob_Gillespie
@marcello.rosadini The new charts should all be working with the webserver now.
Message 7 of 8
boris_vidal
Hi Jacob, I still have the same problem with the dashboard as I wrote in this post.: https://answers.flexsim.com/questions/48713/issues-of-webserver-contains-dashboard.html?childToView=...
I tried another time, without success, with version 2020.0.0
Message 8 of 8
tanner_p
Hi @Boris V2,
My recommendation is to close your dashboard, reset the model, open the dashboard again, and then run the model and see if it works. This is a common issue. Let us know if that resolves it.
Note: It's generally best practice to post a new question and reference the old one on Answers so that your question is seen. Thanks!
