[ FlexSim 24.2.1 ]
I need help with the WebServer. At first, the installation worked perfectly, and I could access the models without any problems. But after following the steps to use IIS, when I try to check which models are available, none show up.
I have reviewed the entire procedure to make sure everything is correct, and when I open FlexsimWeb, the login panel appears where I can enter my username and password. However, once inside the Web Server view, the model dropdown is empty.
I have checked to make sure it's not an issue with folder access permissions, but I haven't been able to fix it (everyone has permission).
Does anyone have any idea what I could do?
Thank you very much.
