Webserver error
Webserver error
rlatngus41386ZRWY
Message 1 of 1
Webserver error
rlatngus41386ZRWY
[ FlexSim 25.0.0 ]
I'm trying to configure the flexsim model to be visible on the webpage, and when I run the installed flexsim webserver, the phrase comes out as below, and when I type any key, it disappears and doesn't work.
I don't know if it's a security issue or what.
↓↓↓↓↓↓↓↓↓↓ERROR↓↓↓↓↓↓↓↓↓↓↓↓↓↓↓↓↓↓↓↓↓
Installing node.js
Failed to retrieve source: msstore
An unexpected error occurred while executing the command.
0x8a15005e : The server certificate does not match the required value.
The following packages were found in the job source.
Use the --source option to specify one of the two to continue.
Name Device ID Source
Node.js (LTS) OpenJS.NodeJS.LTS winget
Please restart the FlexSim Webserver
Press any key to continue.
Replies (0)
