Way to set "Optimize Column for Lookup" with FlexScript
axel_kohonen
axel_kohonen
[ FlexSim 17.2.5 ]
Is it possible to set a certain column in a Global table in bundle mode to "Optimize Column for Lookup" with FlexScript and how in that case?
And is there any more info on when it i wise to use the column indexing which it seems that the optimization does according to this thread? I assume that it adds some overhead.
And if there would be something about this in the manual it would be great! Looked in the 18.0.2 manual as well.
Thank you!
Kind regards,
Axel
Matthew_Gillespie
data is the node holding the bundle data
startCol is 0 based
//Toggle on
applicationcommand("addindextobundlefield", data, startCol, BUNDLE_FIELD_INDEX_MAP);
//Toggle off
applicationcommand("removeindexfrombundlefield", data, startCol);
Matthew Gillespie
FlexSim Software Developer
jing_chen
Hi @Matthew Gillespie.
It seems not working in 17.2. Does it only work in FlexSim2018?
axel_kohonen
Thank you @Matthew Gillespie
It works nicely! Any more info on when it makes sense to optimize columns and when not?
@jing.chen
It does work for me in FlexSim 17.2.5 so not sure what is not working for you.
