Watch variable inside an object
jorge_manuel_garcia
jorge_manuel_garcia
[ FlexSim 16.1.2 ]
Hi everyone:
Is there a way to add to the "Watch Variables" list, a variable that is inside an object?
I'd like to add the variable Trip, which is inside InQueue, how can I add it? I tried "InQueue/Trip" and "InQueue/labels/Trip" without success.
Thanks in advance!
Matthew_Gillespie
You can just use the getlabel command:
getlabel(current, "Trip")
Matthew Gillespie
FlexSim Software Developer
jorge_manuel_garcia
Thanks Matthew, but if the object is not "current"? can I reference it by the name?
Matthew_Gillespie
No, but you can reference objects by path using the node command:
node("InQueue", model())
So to get the label you'd say:
getlabel(node("InQueue", model()), "Trip")
Or you could just use the path to the label:
getnodenum(node("InQueue>labels/Trip", model()))
Matthew Gillespie
joerg_vogel_HsH
Or you try to use the sampler. You write your code until you need an object's reference, then you pick the Sampler and move the pipette icon ( eye dropper element) over this object you want to point and click the left mouse button. Then a list pops up and you choose a suggestion from the items of node. After the reference is put to your code, you write on the code.
Maybe it become obvious what I tried to show in the video at time stamp 5:44 or this video at 3:37. The time stamp is already set in the link.
