Warehouse rack, initial stock filling problem
riccardo_p3
riccardo_p3
[ FlexSim 21.1.1 ]
I have a problem in my model with the rack filling with the initial stock. I want to put on the shelf some initial stock that make the AGV able to work from the start of the model. So i define a source and a queue and the output logic with the global list that I have defined in the model.
The source create the object flow, but the rack isn't able to find a position for the object. I tried the solution with the create object in the process flow but the result is the same.
I attach the script of the error and a copy of the model
Thank to all
Riccardo
AGvThesis_rev28.fsm
moehlmann_fe
The items you create as initial inventory are missing the "LoadUnit" label, that you use for slot assignment. That's why no slot can be assigned.
agvthesis-rev28_fm.fsm
Ben_WilsonADSK
Hi @Riccardo P3, was Felix Möhlmann's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
