waitforevent and pullfromlist not functioning in model
10Dulkar
10Dulkar
[ FlexSim 21.2.0 ]
hi, can you please debug the model and let me know why the list is not pulling the object and the first object once pulled from the list still showing up in the queue and because of that the next object is not getting pulled. I cannot figure out the issue. Please help. extremely urgent. @Matthew Gillespie
moehlmann_fe
You are pushing the items onto the list twice. Once in the entry trigger of the queues and once in the "Send to Port" option.
Either delete the trigger or choose "Do Not Release Item" for the port option.
10Dulkar
hi Felix,
thank you for the answer, but I am still not able to figure out . i checked everywhere and nothing is getting pushed into the list in the entry control. Push to list is only at send to port in the Queues. Can you please elaborate or point where to look. Sorry, I am fairly new to FlexSim
moehlmann_fe
This trigger exists on all queues connected to sources as far as I could tell and pushes the items to the repsective lists.
10Dulkar
I found it. For some reason it was not showing up earlier, may be i was doing something wrong. Thank you for your help.
