Using Labels vs. global table for 20+ variables?
hai_l2
hai_l2
[ FlexSim 20.1.2 ]
When I need to track 20+ variables, is it better to use labels or a global table to track them? Ultimately, the data is written into the global table after the 500 steps activity is completed.
Is there a performance hit for having too many labels?
Is it worse than writing to the global table too often?
Hai
JordanLJohnson
Models are rarely slow because of the number of labels on an object or the number of times you write to a table. It seems unlikely that one approach over the other will be noticeably different. Most models have hundreds or thousands of items or tokens, all of which have 20+ labels, and it is not a problem. Many models also write to global tables thousands of times without noticing a speed difference. Usually, writing values, either to a label or to a table, is a very tiny percentage of what the CPU needs to do to run a simulation.
Jordan Johnson
Principal Software Engineer
hai_l2
Thank you.. without knowing the internal, it is hard for me to guess which is better. Thanks!
