Using Global Macro in Query ?
aditya_prakash1
aditya_prakash1
[ FlexSim 16.1.0 ]
Why query doesn't support Global Macros ? When I write this "WHERE (puller.active_flag == ON AND shift_query == ON)" instead of "WHERE (puller.active_flag == IsActive() AND shift_query == IsActive())" flexsim gives the error "exception: Invalid SqlQuery object". On the other hand IsActive() query works perfectly.
PA: IsActive() just returns the global macro ON.
joerg_vogel_HsH
Maybe different datatype?
aditya_prakash1
No Jörg, both are num for sure.
JordanLJohnson
This is a known issue. If you are using the query command in FlexScript, you can use the $ syntax, and use the macro as an appropriate argument.
query("WHERE puller.active_flag == $1 AND shift_query == $1", ON)
If you are using the Pull From List activity in Process Flow, you can make a user command, as you demonstrated above. You could also look in to using a list field.
Jordan Johnson
Principal Software Engineer
aditya_prakash1
