Use ASRS vehicle with conveyors
Andres_P1
Andres_P1
[ FlexSim 22.2.2 ]
Hi, I'm trying to use vehicle ASRS to save a box in a rack using process flow. The slot assignment is random and I need the transporter to put the box in the correct conveyor connected to that rack but I can´t make the transporter put the box in the right conveyor.
The process is the transporter takes the box from a queue, then travel with the box to the right conveyor connected to the rack where the slot is assigned to that box and then the ASRS vehicle takes it a save it in the slot.
joerg_vogel_HsH
You need an exit transfer at a conveyor and you have to activate the option use transport in this exit transfer. You have to control the routing of items yourself. The only information you can work with, is your assigned slot for this item. You can get all properties from this slot for example the rack object of this slot.
jason_lightfoot_adsk
Many students from your university are posting questions about the same model - (24 open questions at the moment) - questions that can be answered with a bit of research and practice using the manual and its included tutorials or by searching the already answered questions.
