Unified block for entity
laitriminh
laitriminh
[ FlexSim 19.0.0 ]
I want Transporter2 when loading and unloading goods, instead of loading and unloading each box (until reaching 150 boxes). Is there a way for Transporter2 to load and unload goods (150 boxes) at once as a unified block?
jason_lightfootVL7B4
The load/unload task is in intended for single items since it may include offset travel that is dependent on the exact location of the object. It also invokes the loadtime as specified on the task executer.
You can alternatively place all your items in a container and load/unload that.
Or load/unload the first item and then move the others with a moveobject activity (to which you can pass an array of items).
laitriminh
I've understood your point. Could you please elaborate more on the solution of placing all items in a container for loading and unloading?
For example, have them stacked in a pallet.
laitriminh
Thank you, Jason.
