Unable to reference counting variable of the outside For Loop
ABajpaiWMKNX
ABajpaiWMKNX
[ FlexSim 23.2.0 ]
For some reason, the increment variable "m" does not register if I use it inside the internal for loop.
I get the following errors:
Reason for using nested for loops: I want to loop through each 'ModelName' column from UniqueModelNames table and then find that 'mth' model name in the 'temp3' table.
ChampionHomes_V8_7_autosave.fsm
Here is the code:
for (int m=1;m<result4.numRows;m++)
int Aggregated_CycleTime_PerModelName = 0;
for (int i=1; i<result3.numRows; i++)
if (result4[1]==result3[2])
cycleTimeMap[result3[3]]=result3[10];
Matthew_Gillespie
You need to use curly braces to define the scope of the outer for loop.
for (int m = 1; m < result4.numRows; m++) {
    for (int i = 1; i < result3.numRows; i++) {
        if (result4[1] == result3[2]) {
            cycleTimeMap[result3[3]] = result3[10];
Matthew Gillespie
FlexSim Software Developer
ABajpaiWMKNX
Aw man! I was beating my head! Such a silly mistake. thanks
