Unable to do distributed experiments on local machine
shashanksiddapur
shashanksiddapur
[ FlexSim 18.2.3 ]
I do have flexsim web server running on port 8080. I can open & run model through web browser using this. I am trying to run distributed experiments on my local machine but nothing happens in the web instance. I am adding the IPv4 address as 127.0.0.1 for the instance and the connection status says connected. Can you please help me with running the distributed experiments?
JordanLJohnson
If your webserver is running on port 8080, you need to specify that in the IP address:
127.0.0.1:8080
Jordan Johnson
Principal Software Engineer
shashanksiddapur
@jordan.johnson
I tried changing the IP address as well but unable to do.
Do you have any document which might help me in using the local machine for carrying out distributed experiments ? I refereed the one for AWS and tried following the steps but could not do it for local machine.
Really appreciate your help.
JordanLJohnson
I don't have any documents that specifically talk about how to use distributed CPUs locally. Have you tried in the LTS version, version 19.0.8?
Jordan Johnson
benjamin_w2
Hi @Shashank S,
Were you able to get this resolved? If so, could you accept the answer? If not, how else can we help?
shashanksiddapur
yes I am trying to run it on latest Flexsim version
shashanksiddapur
Hi @Benjamin W2 , it is still not resolved. I will try working on it on my own
