Unable to display user library
chanykE2WUT
Observer Observer
chanykE2WUT
Observer
Observer
[ FlexSim 24.2.1 ]
Hi I have added two user libraries, but only one of them is displayed.
When I renamed the second user library with a different name, it works.
It should be a bug which back dated to a few version before.
David
jason_lightfootVL7B4
This feels like an extreme edge case - why would you load the same library twice? If they're two different libraries they should have different names reflecting their content.
chanykE2WUT
Observer
Observer
@Jason Lightfoot actually I have loaded two user libraries. The tree named both of them as User Library 1. Hence only one of the library is displayed on the Library on the left hand side. When I renamed one of them on the tree as User Library 2, then I can see both libraries display properly at the left hand side.
David
The 'tree' didn't name them when you loaded them - they were saved with those names. Since they're different libraries, you should have named them differently before you saved them using the tool provided here:
chanykE2WUT
Observer
Observer
@Jason Lightfoot Thanks. I did not realized that.
I need to change the name of "User Library 1" before I save the library. Then I can have the respective library opened accordingly. Thanks
David
logan_gold
Hi @David Chan, will you please click the "Accept" button at the bottom of the answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
chanykE2WUT
Observer
Observer
@Logan Gold I could not find the accept button. Please help me to close the case.
David
