Hey folks,
I'm trying to follow the instructions here for using FlexSim XML (.fsx format) to save a model. I've successfully used the "split-points" file map method but haven't been successful using the "single-node" to save off the "/Tools/active" node. I think that saving the attached .fsx model in FlexSim should create a new "windows.fsx" file but that isn't happening on my system. Can someone help me understand why this isn't working?
In trying to debug this I noticed that the "active" node doesn't appear to be a child of the "Tools" node so perhaps it isn't working since "/Tools/active" isn't a valid path. In fact, all of the objects in the "View" view under "Tree Navigation" don't seem to exist as children of the "Main" tree. Furthermore, I don't see any of those nodes in the model .fsx file which I expect to contain all of the details of the model. Does "active" and the other "View" objects exist in a tree separate from "Main"?
I talked with Sam at FlexSim today but we weren't able to readily identify or resolve the issue. I've attached the model.fsx, fileMap.ffm and distributedfiles folder I created while following the tutorial. creating-a-windows-fsx-file.zip
Thanks.
